Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2011, 03:12 PM   #1
Angry
Plumbing
I want to install my washer in the basement the problem im having is the drain line is above the floor around six feet.How would i do the piping for this washer?
toad605 is offline   Reply With Quote
Old 03-19-2011, 03:22 PM   #2
Installing washer in basement.
[quote=toad605;612699]I want to install my washer in the basement the problem im having is the drain line is above the floor around six feet.How would i do the piping for this washer?Thanks
Old 03-19-2011, 07:37 PM   #3
Rewards Points: 1,596
You can get a pump system to pump it up to the drain line or mount the washer on a 6' high table as an alternative.
bob22 is offline   Reply With Quote
Old 03-20-2011, 10:40 AM   #4
Just call me Andrew
Rewards Points: 1,020
Don't washers have built-in pumps? The drain for my washer is about 5' off the floor.
Andrew
secutanudu is offline   Reply With Quote
Old 03-20-2011, 01:06 PM   #5
Owner
LateralConcepts's Avatar
The pump in your washing machine was never designed to be used as a lift pump, and shouldn't be used as one.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 03-20-2011, 02:44 PM   #6
most washing machines are rated for 5-8 feet of lift, but the taller it goes the more risk of burning out the pump you have. also, my code says you have to have an 18" stand pipe on top of the trap for a laundry drain. that's gonna max out the washing machine very quickly. if it were me, i'd put in a small pump basin for the washing machine and probably put in a sink to drain it into as well. they're not that expensive, here's one from amazon that would work perfect http://www.amazon.com/Liberty-Pumps-...0650060&sr=1-2
the_man is offline   Reply With Quote
Old 03-20-2011, 03:12 PM   #7
yes thats fine to use a sink pump system but u have to use a vent line which theres not one in that area..
Old 03-20-2011, 05:34 PM   #8
Just call me Andrew
not sure what you mean here...
Andrew
Old 03-20-2011, 06:01 PM   #9
yes you will need to find a vent line both for the pump basin and for the sink trap. you cannot use an AAV (studor vent) for this b/c of the pump basin
Old 03-21-2011, 07:08 AM   #10
Rewards Points: 1,216
My drain hooks in the waste line about 6 ' washer has been running for 21 years now flawless.
COLDIRON is offline   Reply With Quote
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 08:55 AM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 07:55 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
