Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2010, 02:55 PM   #1
Plumbing
I just had new faucets installed. When we turn the faucets on quickly, there is a clunking sound at about 1/4 turn. When we turn them on vey slow, there is not clunking sound.
jimmeru is offline   Reply With Quote
Old 09-08-2010, 08:05 PM   #2
Licensed Master Plumber
check your water pressure
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 09-11-2010, 11:55 PM   #3
Rewards Points: 150
sounds like water hammer
rudolph58 is offline   Reply With Quote
Old 09-12-2010, 09:49 AM   #4
Rewards Points: 1,512
There may be some debris or a tiny pebble or a blob of solder trapped in the pipe. If you are lucky it will come out if you disassemble the faucet as much as possible from the outside and then turn the water on full blast for a second or two.
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 08:55 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
