Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2008, 09:58 AM   #1
plumbing
what size air compressor to blow out water pipes at lake house
jack mcswiggin is offline   Reply With Quote
Old 10-22-2008, 10:25 AM   #2
Tank size will be the important issue here. Less than a 10 gallon tank could make it a time consuming process, depending on how much pipe needs to be done. This is one of those "bigger is better" times.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-22-2008, 01:55 PM   #3
Rewards Points: 1,910
If you are talking DWV pipes just pour RV antifreeeze into the traps.
If you are talking water supply lines an oil lubed compressor will contaminate the lines with oil. Can you just gravity drain the supply lines?
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 09:36 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
