Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2012, 03:37 PM   #1
pug
plumbing
what type of toilet has the water supply in the back of the tank not from the bottom
pug is offline   Reply With Quote
Old 12-01-2012, 04:10 PM   #2
Rewards Points: 14,014
Never heard of one. Why you asking?
Old 12-01-2012, 04:53 PM   #3
pug
im trying to find parts for someone but i do not know the brand but i know what it looks like .the line feeds from the top left side of the back of the tank .it also has a small shutoff valve inside the tank ,it is old.
Old 12-01-2012, 04:57 PM   #4
Get a picture.
Old 12-01-2012, 05:47 PM   #5
DIY staff
Rewards Points: 7,174
Is this in the UK?
Old 12-01-2012, 05:53 PM   #6
Good point, unless you go back and add where your location is, really hard to make suggestions.
Old 12-01-2012, 06:20 PM   #7
pug
sorryyour answers are important .the toilet is in long island ny it is a old toilet,an the flush handle will flush in 2 direction .everything inside the is made of brass .it does have a ball float w/set screw.the problem is the water keeps running .i never seen one like this.
Old 12-01-2012, 06:34 PM   #8
Rewards Points: 582
most of the very old ballcock assy had replaceable seats...shut off water ..take apart the top where float are hooks up to there should be rubber disk seat ... you may be able to install fluidmaster to replace it ...
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 08:55 AM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
