Old 11-14-2012, 08:45 PM   #1
imayearin's Avatar
Plumbing
Needing to calculate how much water I should account for to drain 40' of 2" pipe, I haven't found a formula yet. There are no cutoffs between cold water/steam units that have bad valves. This "house" is a nightmare lol 8)
Trying to replace valves that failed and were bypassed, designated cold water pumps are fed from heat exchangers, three pipe to four pipe...omg I'm too green for this!!!
imayearin is offline   Reply With Quote
Old 11-14-2012, 09:07 PM   #2
Super Moderator
Plumbing
What we need is a math genius-----flying guess? About 3 buckets full----let's see that a mathematician has to say---
Old 11-14-2012, 09:15 PM   #3
Thread killer
Plumbing
A little over 6.5 gallons
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 11-14-2012, 09:36 PM   #4
imayearin's Avatar
Plumbing
I'd take an evilt genius with a floating cork at this point
Old 11-14-2012, 09:37 PM   #5
imayearin's Avatar
Plumbing
Thanks canucker, do you have the formula handy?
Old 11-14-2012, 09:43 PM   #6
Plumbing
there is 231 cubic inches in a gallon
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 11-14-2012, 09:43 PM   #7
Plumbing
Volume of a cylinder is pi*r(squared) * height (or, in this case, length).
So, for a 2" diameter pipe, the volume would be 3.14 * 1 * 480 = 1507 cubic inches = 6.5 gallons.
For unit conversion, Google is your friend. Just google "1507 cubic inches in gallons" and it'll spit out an answer.
TheBobmanNH is offline   Reply With Quote
The Following User Says Thank You to TheBobmanNH For This Useful Post:
imayearin (11-14-2012)
Old 11-14-2012, 09:45 PM   #8
Plumbing
volume of a sphere is pi (3.14) r squared times height or length
Old 11-14-2012, 09:58 PM   #9
imayearin's Avatar
Plumbing
My phone shows no posts by me, but I appreciate everyone!!!!
Making new plumbing connect to old Cast Iron plumbing fallvitals Plumbing 12 10-13-2012 06:52 PM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
