Old 08-27-2012, 06:46 PM   #1
Plumbing
I changed the ballcock on my toilet and I was tightening the plastic coupling nut and it broke off. Is there a way to remove the nut from the water supply line so I can replace it.
Capthu is offline   Reply With Quote
Old 08-27-2012, 07:30 PM   #2
Plumbing
If you are asking about the nut that attaches to the shut-off valve, then no if it has a brass furrel on it. New supply lines are only a couple bucks.
danpik is offline   Reply With Quote
Old 08-28-2012, 09:26 AM   #3
Plumbing
years ago some of the plastic nuts would just barely squeeze over the 3/8 compression nuts. worst that will happen is you will have to buy a new supply line.
Old 08-28-2012, 11:12 AM   #4
Master Plumber
Javiles's Avatar
Plumbing
New supply line about 5 bucks @ H/D why chance a flood.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is online now   Reply With Quote
Old 08-28-2012, 12:55 PM   #5
DIY Enthusiast
Plumbing
+1 buy a new supply line. I found one the other day that has a built-in torque limiter to prevent this sort of thing.
Good luck!
ajmckay is offline   Reply With Quote
Old 08-28-2012, 03:47 PM   #6
Plumbing
I actually went to lowes and was told to buy a new supply line which cost about $5.00. Thanks all for your input.
Under-slab or In-slab plumbing? CplDevilDog Concrete, Stone & Masonry 1 06-13-2012 07:43 AM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
