-   -   Plumbing (http://www.diychatroom.com/f7/plumbing-155040/)
Capthu 08-27-2012 05:46 PM
Plumbing
I changed the ballcock on my toilet and I was tightening the plastic coupling nut and it broke off. Is there a way to remove the nut from the water supply line so I can replace it.
danpik 08-27-2012 06:30 PM
If you are asking about the nut that attaches to the shut-off valve, then no if it has a brass furrel on it. New supply lines are only a couple bucks.
DannyT 08-28-2012 08:26 AM
years ago some of the plastic nuts would just barely squeeze over the 3/8 compression nuts. worst that will happen is you will have to buy a new supply line.
Javiles 08-28-2012 10:12 AM
New supply line about 5 bucks @ H/D why chance a flood.
ajmckay 08-28-2012 11:55 AM
+1 buy a new supply line. I found one the other day that has a built-in torque limiter to prevent this sort of thing.
Good luck!
Capthu 08-28-2012 02:47 PM
Plumbing
I actually went to lowes and was told to buy a new supply line which cost about $5.00. Thanks all for your input.
