Old 07-28-2012, 10:42 AM   #1
plumbing
putting the pipes for your plumbing in the attic, good idea or bad
susan jones is offline   Reply With Quote
Old 07-28-2012, 10:49 AM   #2
Doing it myself
Alan's Avatar
plumbing
Doesn't make much difference in my area. Our climate is quite mild here.
Others might tell you that they need to be well insulated in the attic to withstand freezing winters.
Other than that, it really doesn't make much difference. There's always the possibility for damage if you have a leak there, but then with two story homes, the plumbing on the second floor always makes that a possibility.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
susan jones (07-28-2012)
Old 07-28-2012, 03:35 PM   #3
plumbing
can we hear more about your situation ?
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is online now   Reply With Quote
Shower Plumbing Set Too Far Back?? plumb_confused Plumbing 2 06-01-2012 08:23 PM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
