Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2011, 08:54 PM   #1
plumbing
I have well water. How do I get more water pressure in all my faucets
little92760 is offline   Reply With Quote
Old 12-03-2011, 09:09 PM   #2
Rewards Points: 582
what is your pressure now.....
Old 12-03-2011, 09:50 PM   #3
not sure exactly ,but when water is on one faucet, it bearly comes out of a different one. and pressure isnt very good at all upstairs
Old 12-03-2011, 09:52 PM   #4
Rewards Points: 582
go to holding tank look at pressure guage...what is pressure..
Old 12-03-2011, 09:56 PM   #5
it shows 90 psj,i think gauge has to be wrong
Old 12-03-2011, 10:10 PM   #6
Rewards Points: 582
yes that is wrong...on well should be 20-40 or 30-50 can you get me a picture of set up ...would help me help you...
Old 12-03-2011, 10:21 PM   #7
dont know how to post pic but. but gauge went down to 40psi.gauge is assoon as it comes through the wall before big blue tank if that helps
Old 12-03-2011, 10:23 PM   #8
Rewards Points: 582
are there any filters on the system that could be clogged causing low water flow...
Old 12-03-2011, 10:27 PM   #9
yes but i keep filter changed regularly
Old 12-03-2011, 10:34 PM   #10
Rewards Points: 582
is the pressure slow from the start or is it ok at start then slows down..
Old 12-03-2011, 10:42 PM   #11
it has never really been that good.i just want to know if i can make it better. i want to put two shower heads in my bathroom and dont think i have enough pressure
to do that
Old 12-03-2011, 10:46 PM   #12
Rewards Points: 582
to do that
thats pretty hard to due on a well system not saying it can't be done just hard alot has to be accounted for... as far as increasing pressure ..you could change pressure switch to 30 -50 ...again would like to see system
Old 12-03-2011, 11:03 PM   #13
do they make another type of pressure switch besides the 30-50. because i had to replace the previous pressure switch that was on the system. and it is a 30-50.i never made no adjustments to the switch but can i?
Old 12-03-2011, 11:08 PM   #14
Rewards Points: 582
you can adjust the pressure on both switches 20-40 30-50 if you read instructions most don't play with them. they are designed for wells you should not play with them....some people do...
Old 12-03-2011, 11:11 PM   #15
thank u for all your help i really appreciate it!!
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 10:12 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
