Old 10-12-2007, 06:03 PM   #1
Unhappy
Plumbing
Just Had A New Tile Floor Installed In Bathroom Now My Toliet
Rock,s Front To Back
BOB123 is offline   Reply With Quote
Old 10-12-2007, 07:35 PM   #2
Home Improvement Guy
ron schenker's Avatar
Plumbing
Bummer
ron schenker is offline   Reply With Quote
Old 10-13-2007, 12:47 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Plumbing
Add shims.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 10-13-2007, 02:38 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Plumbing
Bob,
As Ron advises, add shims. There are beveled plastic shims made for the purpose to level toilets.
Put a level across the bowl, shim the base level and snug the toilet bolts down so that the toilet cannot rock or move at all.
If your toilet has been rocking, you will need to replace the wax ring before resetting the toilet. To seal properly with a wax ring, the toilet flange should be bolted on top of the finished floor level with only the thickness of the flange itself above finished floor level.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-14-2007, 09:20 AM   #5
Plumbing
Mike Thank,s For Your Answer ,when I Had The New Tile Floor Done
They Put Two New Wax Rings On,can I Just Remove The Bolts Then
Add Shims Or Will I Have To Remove The Toliet Again
Bob
Old 10-28-2007, 01:11 PM   #6
Plumbing
iv just had an electric shower fitted after using shower i have no hot water for washing up ect
starglitterbug@hotmail.co is offline   Reply With Quote
Old 10-28-2007, 01:23 PM   #7
Long-Time DIYer
Plumbing
Bob,
If it were me, I would get a new plain wax ring and another wax ring with the plastic horn to go on top, scrape the two existing rings out, and replace them. Then reset the toilet and level it with the shims.
You could try it without removing the toilet by just loosening the bolts, adding the shims, and then see if it leaks. I wouldn't chance it if it's upstairs, tho.
Good luck!
Mike
Old 10-28-2007, 01:24 PM   #8
Long-Time DIYer
Plumbing
stargbug,
Please ask your question under its own topic. TY, Mike
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 01:41 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
Shower Plumbing Ron Plumbing 1 08-15-2007 12:38 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
New home plumbing cost wdsfr1968 Plumbing 7 07-28-2006 10:41 AM
