-   -   Plumbing (http://www.diychatroom.com/f7/plumbing-12328/)
BOB123 10-12-2007 05:03 PM
Plumbing
Just Had A New Tile Floor Installed In Bathroom Now My Toliet
Rock,s Front To Back
ron schenker 10-12-2007 06:35 PM
Bummer
Ron The Plumber 10-12-2007 11:47 PM
Add shims.
Mike Swearingen 10-13-2007 01:38 AM
Bob,
As Ron advises, add shims. There are beveled plastic shims made for the purpose to level toilets.
Put a level across the bowl, shim the base level and snug the toilet bolts down so that the toilet cannot rock or move at all.
If your toilet has been rocking, you will need to replace the wax ring before resetting the toilet. To seal properly with a wax ring, the toilet flange should be bolted on top of the finished floor level with only the thickness of the flange itself above finished floor level.
Good Luck!
Mike
BOB123 10-14-2007 08:20 AM
Mike Thank,s For Your Answer ,when I Had The New Tile Floor Done
They Put Two New Wax Rings On,can I Just Remove The Bolts Then
Add Shims Or Will I Have To Remove The Toliet Again
Bob
starglitterbug@hotmail.co 10-28-2007 12:11 PM
iv just had an electric shower fitted after using shower i have no hot water for washing up ect
Mike Swearingen 10-28-2007 12:23 PM
Bob,
If it were me, I would get a new plain wax ring and another wax ring with the plastic horn to go on top, scrape the two existing rings out, and replace them. Then reset the toilet and level it with the shims.
You could try it without removing the toilet by just loosening the bolts, adding the shims, and then see if it leaks. I wouldn't chance it if it's upstairs, tho.
Good luck!
Mike
Mike Swearingen 10-28-2007 12:24 PM
stargbug,
Please ask your question under its own topic. TY, Mike
