| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Basement Remodeling: Furnaces & Other Services
by Expert Village
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
How the Kitchen Plumbing Works
by Expert Village
Once you get all of your plumbing in. Now on this sink, the drain is set forward from the drains coming out of the sink because of the remodel. This inlet right here is going to go to the dishwasher on this side of the sink. We had to use a flexible hose... Read More »
How to Shut Off the Water in Your Home
by Expert Village
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
Basement Remodeling: Applications & Permits
by Expert Village
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. In most cities, you'll be required to pull a permit, when finishing your basement. If you maintain open communications, with the city, they'll be able to... Read More »
How to Take Copper Pipes Apart
by eHow.com
Taking copper pipes apart may be necessary if you're remodeling an older home or if you have a leak between a pipe and a fitting. It's a job the home handyman can handle with the right tools. Just follow the steps below. Read More »
