Old 06-08-2010, 12:30 PM   #1
Plumbing 101
Hello to all We have a home built in 1927 and are currently doing a full reno of the basement. My problem is we would like to put a back water valve to protect our home since we have had back up happen a couple of times through our washer drain. The confusion is with our washer drain which is 5 inches from the foundation wall. There is currently just a loose PVC tube about 2 feet in length just sitting loosely in the drain with the drain hose of the washer sitting in the top of that. I'm thinking this cant be right and need to know what has to be done to correct this problem.
Shamus
Darjordan is offline   Reply With Quote
Old 06-08-2010, 02:00 PM   #2
Owner
LateralConcepts's Avatar
Plumbing 101
It doesn't sound like your laundry drain is plumbed to code. The laundry drain needs to be 2" and trapped. I would have a licensed plumber take a look at it. Additionally, if your home was built in 1927 your main sewer line is most likely made of vitrified clay pipe. If you have had problems with sewage backup it would indicate there is a problem in the main building sewer between the house and the street. If so, that could cost thousands to repair. You may want to consider having it inspected prior to your remodeling project. Unfortunately I've seen gorgeous remodels ruined by disgusting back-ups. If you're still considering a backflow preventer, depending on your landscape and depth of the main, it would be an easier install in the 4" building sewer outside as opposed to jack-hammering or saw cutting the floor inside. Here's an example. http://cleancheck.com/
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
Darjordan (06-17-2010)
Old 06-09-2010, 09:53 AM   #3
Plumbing 101
Sounds like your washer set-up is a simple one using a floor drain for the washer water discharge. For all intents and purposes, it is legal since the floor drain has a trap. The length of PVC pipe is probably to meet the height recommended by the washer manufacturer so the machine doesn't drain during usage. Basically, you could install some clamps to hold the PVC tighter. I would also recommend at least a one inch air gap between the PVC and the top of the floor drain.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
How to find plumbing distributors for plumbing invention? Timster Plumbing 7 05-20-2009 02:53 AM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
