Old 09-01-2009, 12:23 PM   #1
K.M.G's Avatar
Plumber's Question..about Toilet drain
Hi
Looks like I'm ripping the sub floor from the Bathroom up
The Toilet Drain is on top of 1/4 Plywood
Do I remove the Drain and then place it back on top of the 3/4 floor+Ditra+tile
Or Do I remove all the old 1/4 and install my 3/4 and use a few Wax wings to set the Toilet back now.
So I don't have to remove the Drain
I was looking and they want $20 for a new Toilet Drain comes in 3" or 4"
What does a average toilet use
K.M.G is offline   Reply With Quote
Old 09-01-2009, 03:50 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
The toilet flange should sit flush on top of the finished floor level with only the thickness of the flange above the finished floor level. It should be bolted securely to the floor.
Then the toilet will seal properly with one wax ring as intended. Do not stack wax rings (or more than two anyway), because you run the risk of squeezing the wax into the pipe and clogging it when you anchor the toilet back down.
You need to look at the size of YOUR drain (aka closet bend drain pipe) to determine what size flange that you need...usually 3" but could be 4".
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-03-2009, 08:51 PM   #3
Mike is right. In addition, it is important to rebuild the floor under the toilet because a leaking closet flange probably rotted the original floor. The 1/4" flooring is entirely too thin to be supportive. Ideally, you should peel the existing flooring back to the floor joists, raise the closet flange to the finish floor height by cutting into the vertical sewer drain below the floor and extending it the proper amount, replace the subfloor with 3/4" plywood, install the new finish flooring, and reset the toilet. Don't use more than one wax ring. If you find that you have to, something isn't right. Good luck!
JerryWatson is offline   Reply With Quote
Old 09-23-2009, 12:48 PM   #4
K.M.G's Avatar
Just like this Right
See all along I have this in my Head
My Next Question what type and kind of Bolts/Screws do I use so they won't Rust and what size
Old 09-23-2009, 03:06 PM   #5
Right. The closet flange can either sit on top of the tile or on top of the sub floor. I would usually plumb it in to sit on top of the sub floor which would make the finish tile surface flush with the top of the closet flange. Use #10 or #12 x 1 1/4" plated Philips or square drive flat or pan head screws, either sheet metal or wood screws, and at least four. Preferably put fasteners in each hole of the closet flange. Make sure the fasteners on either side of the closet bolt holes are particularly solid. Do not use bent over nails, sheet rock screws, or no anchors at all.
Best of luck!
Jerry
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
how many turns is acceptable on toilet drain moegumble Plumbing 6 08-13-2009 11:28 PM
Toilet Drain Question md2lgyk Plumbing 3 08-05-2009 12:01 AM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 11:12 AM
toilet won't drain scatterbrain General Discussion 14 02-03-2008 01:52 AM
