Old 10-07-2012, 12:19 PM   #1
Plumbers putty or puttyless washer?
I'm getting ready to replace a sink drain in a pedestal sink. Unfortunately, replacing the sink drain in this particular sink is a real PITA, so I'd prefer not to do it again.
The Keeney drain I picked up at Lowe's comes with a puttyless washer, which I've never used before. Do you think the puttyless washer is okay or should I stick with traditional plumber's putty? BTW, I take it I shouldn't use both, correct?
Thanks,
Kelly
kcrossley2 is offline   Reply With Quote
Old 10-07-2012, 01:38 PM   #2
some drains used to come with 2 washers for the bottom, one rubber
and one fiber or paper as a friction washer so the rubber washer didn't
spin out as you tightened the nut. i always threw the ones for the top
away and used putty. never had a problem for the 20 years a did
plumbing.
Old 10-07-2012, 01:58 PM   #3
call me E
TheEplumber's Avatar
plumbing.
+1
Putty has always worked.
plumbers putty or not ? petros151 Plumbing 4 07-14-2012 01:43 PM
Plumbers Putty on Plastic index1489 Plumbing 0 03-19-2012 12:37 PM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 09:19 PM
Clear Silicone instead of Plumbers Putty jmacx81 Plumbing 2 04-29-2009 07:14 AM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 11:03 AM
