-   -   Plumbers putty or puttyless washer? (http://www.diychatroom.com/f7/plumbers-putty-puttyless-washer-159273/)
kcrossley2 10-07-2012 12:19 PM
I'm getting ready to replace a sink drain in a pedestal sink. Unfortunately, replacing the sink drain in this particular sink is a real PITA, so I'd prefer not to do it again.
The Keeney drain I picked up at Lowe's comes with a puttyless washer, which I've never used before. Do you think the puttyless washer is okay or should I stick with traditional plumber's putty? BTW, I take it I shouldn't use both, correct?
Thanks,
Kelly
DannyT 10-07-2012 01:38 PM
some drains used to come with 2 washers for the bottom, one rubber
and one fiber or paper as a friction washer so the rubber washer didn't
spin out as you tightened the nut. i always threw the ones for the top
away and used putty. never had a problem for the 20 years a did
plumbing.
TheEplumber 10-07-2012 01:58 PM
plumbing.
+1 :thumbsup:
Putty has always worked.
