Old 07-14-2012, 12:25 PM   #1
plumbers putty or not ?
I bought a new SS sink and the instruction for installing the basket do not mention putty. There is a rubber washer and then the last washer to contact the inside of the sink is a paper washer. Is this something new that eliminates having to use putty ? If i did use putty would I just put the bead on first and the put the washers on top of the bead ? OR put the washers on first and then the bead ?
thanks!
petros151 is offline   Reply With Quote
Old 07-14-2012, 12:47 PM   #2
MarginallyQualified
Originally Posted by petros151 View Post
the instruction for installing the basket do not (specifically) mention putty.
certain things are assumed (I assume)
Strainer Flange
Putty
Sink
Paper Gasket
Rubber Washer
Big Nut
The Following User Says Thank You to TarheelTerp For This Useful Post:
ben's plumbing (07-14-2012)
Old 07-14-2012, 01:02 PM   #3
Strainer Flange
Putty
Sink
Paper Gasket
Rubber Washer
Big Nut
ok I just re-read the install instructions, they say this:
basket
rubber washer
sink
rubber washer #2
paper washer
big nut
no mention of putty ......
so again is this standard now to use the rubber washer and not putty? Which is considered best putty or washer? I assume never both...?
thanks!
Old 07-14-2012, 01:11 PM   #4
call me E
TheEplumber's Avatar
basket
rubber washer
sink
rubber washer #2
paper washer
big nut
thanks!
Putty or silicone is industry standard. Toss the top casket
Sent from my iPhone using DIY Forum
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 07-14-2012, 01:43 PM   #5
ok thanks! I will stick with the putty.... and I'll toss that Gasket into a Casket and bury it in the back yard
Plumbers Putty on Plastic index1489 Plumbing 0 03-19-2012 12:37 PM
Disposal torque removes plumbers putty cpowersr2 Plumbing 4 01-17-2011 08:46 PM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 09:19 PM
Clear Silicone instead of Plumbers Putty jmacx81 Plumbing 2 04-29-2009 07:14 AM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 11:03 AM
