-   -   plumbers putty or not ? (http://www.diychatroom.com/f7/plumbers-putty-not-150219/)
petros151 07-14-2012 11:25 AM
1 Attachment(s)
I bought a new SS sink and the instruction for installing the basket do not mention putty. There is a rubber washer and then the last washer to contact the inside of the sink is a paper washer. Is this something new that eliminates having to use putty ? If i did use putty would I just put the bead on first and the put the washers on top of the bead ? OR put the washers on first and then the bead ?
thanks!
TarheelTerp 07-14-2012 11:47 AM
Originally Posted by petros151 (Post 965496)
the instruction for installing the basket do not (specifically) mention putty.
certain things are assumed (I assume)
Strainer Flange
Putty
Sink
Paper Gasket
Rubber Washer
Big Nut
petros151 07-14-2012 12:02 PM
Strainer Flange
Putty
Sink
Paper Gasket
Rubber Washer
Big Nut
ok I just re-read the install instructions, they say this:
basket
rubber washer
sink
rubber washer #2
paper washer
big nut
no mention of putty ......
so again is this standard now to use the rubber washer and not putty? Which is considered best putty or washer? I assume never both...?:huh:
thanks!
TheEplumber 07-14-2012 12:11 PM
199 Attachment(s)
basket
rubber washer
sink
rubber washer #2
paper washer
big nut
thanks!
Putty or silicone is industry standard. Toss the top casket
Sent from my iPhone using DIY Forum
petros151 07-14-2012 12:43 PM
ok thanks! I will stick with the putty.... and I'll toss that Gasket into a Casket and bury it in the back yard :laughing:
