Old 02-08-2012, 07:16 PM   #1
plumber's putty needed?
I had to put in a bushing for the tub drain then just screwed the shoe and its gasket into the drain. I can't see a leak. Do I need plumber's putty and if so do I put it on the gasket or the inside of the bushing or between the under lip of the shoe and the gasket?
steve_vandalay is offline   Reply With Quote
Old 02-08-2012, 07:21 PM   #2
Not a clue what you mean by a bushing for the drain. The strainer just screws into the drain shoe, no "bushing" involved.
If there's a rubber gasket under the drain flange you should be fine with out the plumbers putty
Old 02-08-2012, 07:24 PM   #3
GC/Master Plumber/Mech
We have stopped using plumbers putty and pretty much only use silicone.
Either use putty or silicone between the drain spud and the tub and not between the rubber gasket and shoe
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-08-2012, 08:21 PM   #4
oh guys please say its not so ...plumbers putty still rules....ALWAYS..
The Following User Says Thank You to ben's plumbing For This Useful Post:
VIPlumber (02-08-2012)
Old 02-08-2012, 11:28 PM   #5
DO IT RIGHT THE 1st TIME!
Ben ill agree - Still use putty here.
builttolast is offline   Reply With Quote
Old 02-08-2012, 11:47 PM   #6
Master Plumber
Javiles's Avatar
The bushing he is referring to is a threaded bushing that comes with a replacement pull and twist drain kit, this is to adapt the smaller threaded drain strainer to an existing shoe, Or vise versa
The answer to your question is gasket between tub and shoe putty between the strainer slash stopper and tub.pipe dope on the bushing, Some of the guys are using silicone and I guess that’s ok but aim an old timer hard to teach an dog new tricks. still a putty user.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Fan size needed for Spray Booth (CFM) Sandy 1150 Painting 0 12-21-2011 08:22 PM
Building a 20' x 20' wood frame garage bgbrown125 Building & Construction 38 08-07-2011 02:53 PM
Face nail needed with Bona r851? bakerzdosen Flooring 0 08-01-2011 08:56 AM
Am I right...teflon tape not needed on new faucet lines? Hossenfeffer Plumbing 2 01-23-2011 02:42 PM
Need advice on quantity of primer and paint needed laurat Painting 8 01-01-2011 11:53 AM
