Old 01-27-2009, 12:51 PM   #1
Plumber's Putty around sink flange
I installed a garbage disposal, stainless flange on stainless sink, I was wondering do you scrape the putty completely clean around the flange? Do you just use your finger nails or is there a better method?
It's kind of weird the putty is still under pressure from the flange, and a little comes out after I wipe it clean, just very little. I guess this will eventually equalize?
DIYGST is offline   Reply With Quote
Old 01-27-2009, 02:49 PM   #2
Remodeling Contractor
Tighten the lower nut, scrape the putty completely with your finger nail and your done. But a disposal also has screws that tighten up to the bottom to keep it from rocking.
Old 02-03-2009, 05:54 PM   #3
DIY Hack
Mr Chips's Avatar
i am having a similar problem, and when i use the disposal i get more of the putty coming out around the flange. the three screws on the bottom of mine are very tight (possibly too tight?) i had this problem before, and it eventually started leaking around the flange
Mr Chips is offline   Reply With Quote
Old 02-03-2009, 05:57 PM   #4
The bolts should be snugged only. Yours sounds like it is too tight causing all the putty to squeeze out
Old 02-03-2009, 06:00 PM   #5
Mine still has a little coming out around the the flange after a week, seemed to be settling down though.
I think the putty is under pressure, eventually when enough of it comes out it should stop?
Also when I run hot water to heat up the flange area, seems to soften the putty and squeeze more out. (maybe you can try this and report back, my faucet isn't hooked up right now)
Flange is tight and I think the putty is still moving around to fill the voids.
Bob, should we loosen the screws, would that cause a leak now?
Old 02-03-2009, 06:34 PM   #6
Master General ReEngineer
Bondo's Avatar
Ayuh,.... I took mine out,+ Threw it away,.... Put a drain back in...
Food belongs in the compost pile,....
The drains are for water,+ the food you've already Eaten.....
Old 02-03-2009, 08:18 PM   #7
not likely. Just add putty again if you need to. These bolts help the unit stay stable while the starting torque tries to make it spin.
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 07:42 PM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 11:03 AM
