Plumber's Putty - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2011, 08:09 PM   #1
Rewards Points: 1,088
Plumber's Putty
Is PP good for higher temperature applications?
I have seen PP used on the return line to seal out condensation for AC systems and the return line is generally hot during the heating months.
handy man88 is offline   Reply With Quote
Old 07-24-2011, 09:11 PM   #2
Rewards Points: 558
Plumbers putty is a substance used to make watertight seals and it remains soft for a long time after it is used and should not be used in a hi heat situation as the putty would break down and cause leaks.
epson is offline   Reply With Quote
Disposal torque removes plumbers putty cpowersr2 Plumbing 4 01-17-2011 07:46 PM
Tub drain instructions say use supplied rubber gasket ; no mention of plumbers putty lazzlazz Plumbing 10 05-21-2010 11:21 PM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 08:19 PM
Clear Silicone instead of Plumbers Putty jmacx81 Plumbing 2 04-29-2009 06:14 AM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 10:03 AM
