Plumber's Grease Safe With ABS Plastic? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2013, 03:41 PM   #1
Rewards Points: 278
Plumber's grease safe with ABS plastic?
I have a drain clean out plug that I think I can tighten it a little bit more, just barely pass hand tight,
It feels the plastic threads are not too lubricated, but I don't want to force with the wrench and risk cracking the stucco it is embedded in.
anyway, would a little plumber's grease on the threads harm the plastic?
Is the plug like a large pipe thread that it gets tighter as it seals?
DIYGST is offline   Reply With Quote
Old 11-05-2013, 03:47 PM   #2
Rewards Points: 12,876
Use Teflon pipe dope instead.
It will lube and seal at the same time.
Old 11-05-2013, 04:28 PM   #3
Rewards Points: 278
Thanks, that did the trick, I was able to get the plug to go in a couple more turns with the fitting with about the same power applied, and it sits flush.
There was standing water at the threads when I took it out, the dope should take up the space and not allow this anymore.
Old 11-05-2013, 05:21 PM   #4
Why was there standing water?
Are you sure the drains not plugged up? There should have been no standing water.
Old 11-05-2013, 05:29 PM   #5
Rewards Points: 278
In my case the clean out plug is only about 2 inch away from the actual drain.
I imagine there is some water splashes as things go down.
Plus when I started this thread my plug was not properly tightened so the water probably collected on the threads.
Plastic Under Sil Plate? ddawg16 Building & Construction 4 11-12-2011 05:33 PM
Tack filler strip to plastic threshold? Richo Carpentry 1 07-09-2011 03:31 PM
Plastic 4mil under interior walls? Avadon Carpentry 4 05-03-2011 07:36 PM
sealtite not plastic underground? walt1122 Electrical 6 04-14-2011 04:39 AM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
