Old 03-24-2008, 09:50 PM   #1
jelly's Avatar
"Plumbers Box"
I have a challange with the new bathroom I put upstairs. Directly below the upstairs toilet is a window below on the first floor. In order to drop down with the 3" sewer line, I will first have to turn 90 degrees cut into a 2x8 floor joist and go down in the next bay. My uncle said that I need to build "plumbers box" in order to support the joist that will have a 3" hole in it. He didn't know exactly how to do it, I googled "plumbers box" but could not find a diagram or information on how to support the joist.
Your thoughts/ideas are appreciated. Thanks and Regards
jelly is offline   Reply With Quote
Old 03-24-2008, 10:08 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
"Plumbers Box"
It's called header out the joist to allow plumbing to fit.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-24-2008, 10:16 PM   #3
jelly's Avatar
"Plumbers Box"
Is this the idea?
Old 03-24-2008, 10:17 PM   #4
Journeyman Plumber
"Plumbers Box"
Thats it.
Old 03-24-2008, 10:26 PM   #5
jelly's Avatar
"Plumbers Box"
Thanks Ron!
Also found this diagram, do you recommend double headers AND double joists?
CHEERS
Old 03-24-2008, 10:44 PM   #6
Journeyman Plumber
"Plumbers Box"
I leave that up to the builder to decide.
Old 03-25-2008, 04:07 PM   #7
Question
"Plumbers Box"
i wonder if this building form is applicable vertically as well as horizontally ?
i would like to build something like this to enable a loop vent where the fixture is two studs away from the drain inlet that goes into the concrete slab.
