-   -   "Plumbers Box" (http://www.diychatroom.com/f7/plumbers-box-18947/)
jelly 03-24-2008 08:50 PM
"Plumbers Box"
101 Attachment(s)
I have a challange with the new bathroom I put upstairs. Directly below the upstairs toilet is a window below on the first floor. In order to drop down with the 3" sewer line, I will first have to turn 90 degrees cut into a 2x8 floor joist and go down in the next bay. My uncle said that I need to build "plumbers box" in order to support the joist that will have a 3" hole in it. He didn't know exactly how to do it, I googled "plumbers box" but could not find a diagram or information on how to support the joist.
Your thoughts/ideas are appreciated. Thanks and Regards
Ron The Plumber 03-24-2008 09:08 PM
It's called header out the joist to allow plumbing to fit.
jelly 03-24-2008 09:16 PM
101 Attachment(s)
Is this the idea?
http://daveosborne.com/newsletters/i...airopening.gif
Ron The Plumber 03-24-2008 09:17 PM
Thats it.
jelly 03-24-2008 09:26 PM
101 Attachment(s)
Thanks Ron!
Also found this diagram, do you recommend double headers AND double joists?
http://www.sweethaven02.com/BldgConst/en5112a0082.gif
CHEERS http://www.panicfreaks.org/images/emoticons/cheers.gif
Ron The Plumber 03-24-2008 09:44 PM
I leave that up to the builder to decide.
amakarevic 03-25-2008 03:07 PM
i wonder if this building form is applicable vertically as well as horizontally ?
i would like to build something like this to enable a loop vent where the fixture is two studs away from the drain inlet that goes into the concrete slab.
