Plumber Turned Water Off, Then Back On - Now Just Have Warm Water... - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2011, 09:41 AM   #1
Plumber turned water off, then back on - now just have warm water...
We had a plumber here to install a fixture in a remodeled shower. He turned the water supply to the house off to do the install, then turned it back on. Since then, we only have very warm water coming into the house, not Hot. How does turning the water supply off then back on affect the water heater? How do you fix this?
sstat is offline   Reply With Quote
Old 02-18-2011, 10:22 AM   #2
DIY staff
Rewards Points: 7,174
If he installed a new shower mixer ---that's the problem--my guess is it's a Delta and he left in the test plug and did not put in the guts (cartridge)--This is allowing "cross over" at the new valve.
Install the cartridge and the problem is gone.
On some occasions this can happen with other brands if the tub/shower head outlets have capped stubouts installed---
The solution there is to rotate the handle stub until the mixer is in the 'off' position.--Mike--
Old 02-18-2011, 10:38 AM   #3
Just call me Andrew
Rewards Points: 1,020
Is the problem everywhere (sinks, etc) or just that new shower?
Andrew
secutanudu is offline   Reply With Quote
Old 02-18-2011, 10:44 AM   #4
DIY staff
I assumed that he installed a new mixer in preparation for a shower re-do----?????
Old 02-18-2011, 01:18 PM   #5
rditz's Avatar
there are also some mixers that have have a procedure for setting the handle position to get proper mixture.. if you still have the directions, check, it may just need to be adjusted.
but I also agree with previous question... "is it EVERYWHERE???
rod
rditz is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Detecting Water Leak in Back Yard melmjd Plumbing 2 11-14-2011 11:56 AM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
