Plumber Said Ok, What Do You Say? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2013, 05:17 PM   #1
Plumber said ok, what do you say?
Doing a kitchen remodel and the layout I've drawn is the layout the plumber outlined in his bid. He said the standpipe/ laundry sink drain layout sizing/venting is acceptable by city. Looking for feedback. To the immediate right of the dishwasher is a door and to the immediate right of the basement stack is another door.
Vipersdeuce is offline   Reply With Quote
Old 01-15-2013, 05:55 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 834
Have the plumber pull permits and inspections- then no worries
I have no idea where you are located or what plumbing code is in your neck of the woods
The Following User Says Thank You to TheEplumber For This Useful Post:
Vipersdeuce (01-15-2013)
Old 01-15-2013, 07:04 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
Add location to your profile, under our code the inspector would have a heart attack if we piped it in according to your drawing.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-15-2013, 07:55 PM   #4
City of Saint Louis...follows UPC 2003.
Old 01-15-2013, 08:21 PM   #5
Roofmaster
Rewards Points: 2,210
Why are you drawing it and not the licensed plumber???
Old 01-15-2013, 08:31 PM   #6
Plumber
Rewards Points: 834
I use UPC '03- your plumber failed miserably
Cannot vertical wet vent 2 floors
more then 1 fixture on a trap
trap arm length too long
need CO at base of stack
etc, etc....
Old 01-15-2013, 09:08 PM   #7
I drew it as he explained it and after talking to some people and reading the code book I wanted to throw the plan out there to you all. Thanks for the info.
Old 01-15-2013, 09:12 PM   #8
Plumber
Rewards Points: 834
It can be piped correctly with a few modifications to your drawing. I'll give your plumber the benefit of doubt that a few details were left out in his description
Old 01-15-2013, 09:19 PM   #9
Would you bring the kitchen sink drain straight down, separately, and tie it below where the laundry sink ties into the stack?
Old 01-15-2013, 09:27 PM   #10
Plumber
Rewards Points: 834
Yes- a 2". I would also figure a way to get the laundry sink off the washer stand pipe- you could discharge the washer directly into the sink
Old 01-15-2013, 09:40 PM   #11
I do have the washer draining into the sink currently. That would count the sink and washer as one fixture? Drain the sinks toward the stack then, with the trap within acceptable distance of the stack?
Old 01-15-2013, 09:51 PM   #12
Plumber
Rewards Points: 834
Yes, the trap and it's arm will be 1.5"- discharging to the 2" vert. drain. Off the top of the drain stack- vent with 1.5" - vent can tie into kitchen sink vent at 42" above the floor- continue with 1.5" combined vent through the roof or to another vent stack. 1.5" max trap arm per UPC is 3'-6"
Old 01-15-2013, 10:00 PM   #13
Plumber
Rewards Points: 834
I can't read what you have at the top for venting but this is what I just discribed
Old 01-19-2013, 08:38 PM   #14
I'm having clearance issues tying my laundry sink trap arm into the stack (using a wye coming off of the stack) given only 16" between the sink and floor. Can I tye into the stack using a San tee with a 90 street el off it going vertically to save some room? Can I bury my wye part way if the wye is the proper way to go? My stack will have a cleanout min 36" off the floor.
And The Leak Goes On!....Two Visits From the Plumber Later spyboy Plumbing 11 04-16-2011 09:12 PM
Dishonest Plumber Left Major [Expensive] Issues ConsumerTalk Plumbing 4 03-27-2011 01:23 PM
Plumber installed thermal Expansion tank without adjusting pre-charge markwo Plumbing 2 01-21-2010 12:41 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 01:14 PM
