Plumber Hell - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2011, 08:33 PM   #1
Plumber hell
I hired a plumber that came highly recommend to do my bathroom addition. We discussed the project ad I told him I do not want to expose the plumbing he assured me that everything would be able to go behind the wall except the waste line that would go into closet that would need to be in a sofit but this is what I'm left with.
Brilliantinc is offline   Reply With Quote
Old 09-17-2011, 08:36 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So all that remains is for you to build your new soffit.
The Following User Says Thank You to Bud Cline For This Useful Post:
Alan (09-17-2011)
Old 09-17-2011, 08:43 PM   #3
Can this not be done with all these connections one plumber that I showed this picture said he could have dropped it lower against that wall so it could Umderwood the beam.
Old 09-17-2011, 09:45 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The opinions you ask for the more opinions you'll get and it still won't be fixed.
Box the ceiling as you said before. You can probably do away with that clamp on the wall and slide a piece of drywall behind that pipe.
It's a problem for sure but it can be dealt with from what I am seeing.
Old 09-17-2011, 09:59 PM   #5
Ok thanks for that so there is nothing I can do coming from the toilet?
Old 09-17-2011, 11:02 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I thought that was the area where you were going to build the soffit.
Maybe the picture is a little deceiving.
Old 09-18-2011, 07:37 AM   #7
Rewards Points: 1,216
Like Bud said close it in. Elevation is important and he has to maintain that for the correct pitch and flow. Cover up time.
COLDIRON is offline   Reply With Quote
Old 10-08-2011, 10:19 AM   #8
Rewards Points: 2,516
Have you remedied you're cover-up problem?
hammerlane is offline   Reply With Quote
Old 10-08-2011, 11:30 AM   #9
Mark Potter's Avatar
Rewards Points: 150
It looks sloppy cuz he should of used street 45s for the sink drain instead of all those other fittings, got primer all over the walls and used a knife to cut sheet rock with.
H|P Capital
Mark Potter is online now   Reply With Quote
Old 10-08-2011, 12:45 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
Getting slightly off topic.....I thought black ABS was the proper stuff to use for waste drains?
ddawg16 is online now   Reply With Quote
Old 10-08-2011, 01:20 PM   #11
Rewards Points: 150
Your correct on that one ddawg.
H|P Capital
Old 10-08-2011, 03:16 PM   #12
DIY staff
Rewards Points: 7,174
Depends on local codes---here it's all schedule 40 PVC--No ABS
Old 10-08-2011, 03:54 PM   #13
JOATMON
ddawg16's Avatar
Why the difference? ABS is softer (more flexible) than PVC....I would think that you would want ABS in cold climates.
Old 10-08-2011, 05:42 PM   #14
Rewards Points: 150
For in ground drainage.
H|P Capital
Old 10-08-2011, 06:07 PM   #15
DIY staff
If something cost more or takes longer to install it is required here---Illinois--
And The Leak Goes On!....Two Visits From the Plumber Later spyboy Plumbing 11 04-16-2011 09:12 PM
Dishonest Plumber Left Major [Expensive] Issues ConsumerTalk Plumbing 4 03-27-2011 01:23 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 01:14 PM
