-   -   Plumber hell (http://www.diychatroom.com/f7/plumber-hell-117561/)
Brilliantinc 09-17-2011 09:33 PM
Plumber hell
3 Attachment(s)
I hired a plumber that came highly recommend to do my bathroom addition. We discussed the project ad I told him I do not want to expose the plumbing he assured me that everything would be able to go behind the wall except the waste line that would go into closet that would need to be in a sofit but this is what I'm left with.
Bud Cline 09-17-2011 09:36 PM
So all that remains is for you to build your new soffit.:)
Brilliantinc 09-17-2011 09:43 PM
Can this not be done with all these connections one plumber that I showed this picture said he could have dropped it lower against that wall so it could Umderwood the beam.
Bud Cline 09-17-2011 10:45 PM
The opinions you ask for the more opinions you'll get and it still won't be fixed.
Box the ceiling as you said before. You can probably do away with that clamp on the wall and slide a piece of drywall behind that pipe.
It's a problem for sure but it can be dealt with from what I am seeing.:)
Brilliantinc 09-17-2011 10:59 PM
Ok thanks for that so there is nothing I can do coming from the toilet?
Bud Cline 09-18-2011 12:02 AM
I thought that was the area where you were going to build the soffit.:)
Maybe the picture is a little deceiving.:)
COLDIRON 09-18-2011 08:37 AM
Like Bud said close it in. Elevation is important and he has to maintain that for the correct pitch and flow. Cover up time.
hammerlane 10-08-2011 11:19 AM
Have you remedied you're cover-up problem?
Mark Potter 10-08-2011 12:30 PM
It looks sloppy cuz he should of used street 45s for the sink drain instead of all those other fittings, got primer all over the walls and used a knife to cut sheet rock with.
H|P Capital
ddawg16 10-08-2011 01:45 PM
Getting slightly off topic.....I thought black ABS was the proper stuff to use for waste drains?
Mark Potter 10-08-2011 02:20 PM
Your correct on that one ddawg.
H|P Capital
oh'mike 10-08-2011 04:16 PM
Depends on local codes---here it's all schedule 40 PVC--No ABS
ddawg16 10-08-2011 04:54 PM
Why the difference? ABS is softer (more flexible) than PVC....I would think that you would want ABS in cold climates.
Mark Potter 10-08-2011 06:42 PM
For in ground drainage.
H|P Capital
oh'mike 10-08-2011 07:07 PM
If something cost more or takes longer to install it is required here---Illinois--
