Plumber Fixed Our H/w Problem - Now Neighbor Isn't Getting Water From One Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2011, 06:15 PM   #1
Plumber fixed our h/w problem - now neighbor isn't getting water from one sink?
Hi..need a bit of advice from the experts
So, a plumber came and fixed a problem we were having with our hot water. To cut a long story short, he replaced a check valve and ball valve on a 1/2" recirculation line coming from our water heater (they were both old and broken). A few days before that as part of the trouble shooting he replaced a mixing valve on one of our shower heads. For the shower repair he had to shut off the main supply to the building. For the 1/2" line, he only shut off our cold water supply.
Fast forward a couple of days and my neighbor downstairs is now telling me she isn't getting any water to one of her sinks. It is only one sink causing the problem - she is getting water everywhere else.
Do you guys happen to know what might be causing this? Plumber is coming back tomorrow and is thinking about capping our 1/2" line. I don't want him to touch it! We each have separate water heaters in the basement. We are on the top two floors in the building and she is on the two lower floors.
Any help much appreciated!
Thanks.
kissiffer4 is offline   Reply With Quote
Old 04-01-2011, 06:24 PM   #2
Plumb or Die!
Plugged aerator. The thingy with the screen inside that the water comes out of. Or used to.
plumber666 is offline   Reply With Quote
The Following User Says Thank You to plumber666 For This Useful Post:
oh'mike (04-01-2011)
Old 04-01-2011, 06:29 PM   #3
Cheers plumber666. Unfortunately I'm a bit of a novice with this stuff. What is the aerator and how easy is it to fix? Is it part of her sink?
Thanks.
Old 04-01-2011, 06:33 PM   #4
Plumb or Die!
Its at the wet end of the faucet. Usually you can unscrew it by hand, maybe you'll have to use a small pair of channel locks (pliers).
Old 04-01-2011, 06:37 PM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,360
If it's the kitchen sink, it could also be a plugged up diverter valve. This is the valve that diverts water to the sprayer, if there is one.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-01-2011, 06:40 PM   #6
Hi Clutch, as far as I know it is the bathroom sink. Could the diverter valve still be a potential problem?
Thanks.
Old 04-01-2011, 06:44 PM   #7
I have gas!
Probably not at this point.
What happens is the plumbing is jostled and some debris flows through the line and gets stuck in the valve. The sprayer would work fine but the faucet only trickles. I think devil plumber is correct. Just clean out the aerator.
Old 04-01-2011, 06:57 PM   #8
Alright. Cheers fellas. There isn't any way the work done to the 1/2" line could affect her is there? It is hooked into our cold water line by the water heater, but I can't imagine how changing the valves would screw up the supply to her sink.
Old 04-01-2011, 06:58 PM   #9
DIY staff
Rewards Points: 7,174
faucet aerator - Google Search
Here is a link to a picture of an aerator----Plumber666 has the likely suspect in hand!
Old 04-01-2011, 10:06 PM   #10
Plumb or Die!
Muah ha ha!!
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
How to Install a Water Line to a Refrigerator With No sink yerac2003 Plumbing 6 05-07-2009 03:27 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
