Plumber Error? "C" Running "H" Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2010, 02:34 PM   #1
plumber error? "C" running "H" water
A plumber came to fix a busted pipe near the hot water heater-now when I turn off the water at the ground, i am still getting water in both faucets but it's all hot coming out both. Did he cross something?
satisfraction is offline   Reply With Quote
Old 11-08-2010, 03:48 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
why do you have a hot water heater? I use mine to heat the cold water. I figure it makes no sense to heat water that is already hot.
just joking.
what are you turning off? the main supply?
Old 11-08-2010, 08:21 PM   #3
Household Handyman
Rewards Points: 1,408
Legitimate question: What are you turning off "at the ground"? If it is the main water supply, you may have some residual pressure on the water heater. Then if you open both faucets on one fixture you will get hot water out of each as the water "bleeds over" from one side to the other. BUT- this should not last but for a few seconds. As stated; this is IF you are shutting off the main water feed to the house.
Please clarify what you are turning off "at the ground". David
Old 11-08-2010, 08:55 PM   #4
Just call me Andrew
Rewards Points: 1,020
Maybe he likes REALLY hot showers?
Andrew
secutanudu is offline   Reply With Quote
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
HOT water running but no cold only in ensuite? coldab Plumbing 6 12-14-2009 08:52 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 07:46 AM
water running down waste pipe rav927 Plumbing 5 07-04-2009 09:24 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
