Plumber Cannot Repair GE Ultra Low NOx Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2013, 10:38 PM   #1
Rewards Points: 682
Plumber cannot repair GE ultra low NOx water heater?
I have a GE water heater with a piezo pilot ignition system, I could not get the pilot to light with several tries. A plumber attempted to fix it, and then explained that this model was trouble, his company could not get the correct thermocouple, and I would have to get parts directly from GE.
Long ago another plumber mentioned this water heater was trouble. The model is GG28T06AXK00. It is a General Electric ultra low NOx 6 year water heater.
Have any of you had trouble with this model of water heater? Looks like I will have to wait to Monday to contact GE, and who knows when till the parts come, and all the time the unit will be without hot water.
darsunt is offline   Reply With Quote
Old 01-12-2013, 10:43 PM   #2
Rewards Points: 682
Also this tank is still under warranty, but I had it installed by a handyman, and I don't have the receipts, ect. I hear GE is pretty sticky about the paperwork for its warranties.
Old 01-13-2013, 12:08 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
IMO- GE gas heaters= trouble
The Following User Says Thank You to TheEplumber For This Useful Post:
DidIDoThat (01-14-2013)
Old 01-13-2013, 12:10 AM   #4
Rewards Points: 1,448
When you look through the little window in the lower hatch, do you see a spark when you press the red piezo (light the pilot) button?
If you wait two hours and come back and follow the procedure for lighting the pilot, does the pilot come on at least for a few minutes while you hold the other small red button down?
See, also, this thread:
Rheem hot water heater - pilot / burner not staying lit?
Old 01-13-2013, 12:23 AM   #5
Rewards Points: 13,300
http://www.consumeraffairs.com/homeo...er_heater.html
Old 01-13-2013, 01:45 AM   #6
Rewards Points: 682
I didn't want to take the time to figure out how to fix the problem because I didn't want the unit to go for too long without hot water. But if the plumber is correct - and you guys say he is correct - then the fix is going to take awhile.
Is there any way to procure GE parts faster? The plumber said the parts are non standard and there is no way for his company to get them.
Old 01-13-2013, 08:23 AM   #7
It is useful to do some troubleshooting up front, so that the proper parts can be ordered. If you don't want to check things yourself then the plumber will end up doing it possibly making multiple visits, possibly ordering unnecessary parts, and likely charging you more altogether.
Old 01-13-2013, 10:28 AM   #8
Plumber
Rewards Points: 452
The only faster way is to replace the whole heater with what the plumber has in stock. Get use to the fact that you're dealing with GE parts.
Old 01-13-2013, 05:29 PM   #9
Rewards Points: 682
Are GE water heaters unique in that their parts are hard to get? Are there other brands like that? I was never too choosy about the brand of my water heaters but maybe I should be.
Also, one plumbing supply warehouse I visited doesn't have Kohler valves for kohler toilets. I like kohler toilets, but will they be a parts problem in the future?
Old 01-13-2013, 06:45 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
You can light the pilot with a match or a stick lighter.
Coastal South Carolina
Old 01-13-2013, 07:11 PM   #11
Rewards Points: 3,418
Anything GE = grief
Canarywood1 is offline   Reply With Quote
Old 01-13-2013, 07:39 PM   #12
Plumber
Rewards Points: 452
Ge's are unique- at least in my area.
Not all supply houses carry kohler nor do all supply houses carry Delta. But they can get any of the parts in a couple days.
In the current economy, very few supply houses carry stock as they did a couple years ago. Now, nobody wants stock sitting on the shelves for very long.
Water Heater Vacuum Breaker Needed??? Trgo Plumbing 1 10-21-2012 07:34 PM
Water heater trouble!!! Please help!!!! k1ngjoe Plumbing 32 04-09-2012 10:57 AM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
