Want to install a laundry sink and washer as shown in the photo. Can I just remove the existing 4"-T from the stack, replace it with a "Double Sanitary T", use one tap of the San T as a clean-out and the other tap as the run for the sink using a wye then onto the washer?
Also will I not need a vent for the sink/washer since it will be close to the stack?
Check out photos and let me know your comments of a better way
That'll definitely work. What I would do though is stack 2 sani 90's on top on each other, cleanout (facing out) on the bottom and the drain (hanging a left) above.
I pulled my code book so I could give you an exact answer. The maximum length for the trap arm (drain from washer to stack) is 2.4m (7' 5"-ish) assuming you're using 2" pipe as the drain.
At least up here it is, your local codes may vary so you might want to ask the local authorities to be certain.
hey guy nice drawings...yes this will work and i believe in ohio if you are within 6' of stack you don't need vent....I would cut a tee under the existing clean out and be done with it....
You will be fine either way---t or y---however,I like VIPs suggestion--having the clean out T facing out will make servicing the line easier---and will be in the correct place if the wall is ever studded out for a finished room.
Idid mean tee it seems to be eaiser for the do it your selfer...however mike and vip also make a good point about possible finish work and access . if your not going to build wall and finish off you should be fine...
Do you think I need the re-vent since the sink stub out will be only about 24" from stack?
If I can eliminate the re-vent, I could take fitting #2 and rotate it so the branch of the T-Wye is the stub-out for the sink and then the run of the T-Wye would go and pick up the P-trap for the washer standpipe.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
