Plugging Unused Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2011, 08:16 PM   #1
Plugging unused drain pipe
There was an old abs drain pipe that goes into my concrete slab. I've remodeled and that pipe us now unused. Before I got a chance to seal it off properly, the concrete guy needed to build a form there. So he cut the pipe flush, stuffed some insulation into the pipe, and mailed down pt wood over it.
Not at all what I would've done, but is this an acceptable way to seal off a pipe?
acerunner is offline   Reply With Quote
Old 03-02-2011, 08:27 PM   #2
Rewards Points: 1,512
Is that drain pipe completely decommissioned, that is, now has nothing connected at both ends?
Particularly if it is below ground level, the pipe needs to be plugged to be sure that ground water does not come up and out of it. Covering it with a non-watertight piece of wood is not the right way to plug it. If you are absolutely sure it will never be used in the future, you could fill it (probably just a foot's worth) with concrete.
Old 03-02-2011, 08:27 PM   #3
Owner
LateralConcepts's Avatar
Umm no. What was the pipe for?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 03-02-2011, 08:35 PM   #4
i'd glue one of these into it http://www.metrosupply.ca/product/12...gs-466378-PG1Q (found with a quick google search). it'll completely seal the pipe, and you'll be able to knock it out and use it in the future if you ever need to
the_man is offline   Reply With Quote
Old 03-03-2011, 12:45 AM   #5
that's what i thought. argh, i hate lazy contractors. The opening is already covered up with with framing. I knew it was wrong, but he argued it was "good enough" and the down time of having to go get the proper part. I eventually gave in.
So far this project has been such a headache, contractor so impossible to convince to change their way. More proof that if you want something done right, gotta do it yourself. I only wish I had the time. /end rant
It used to be the drain for a kitchenette/laundry, 2" pipe.
Old 03-03-2011, 08:31 AM   #6
i'd grab a sawzall, open it up, and seal it properly. you now have a pipe that will let sewer gas in the house as well as a pipe that could cause a flood if the main ever backs up. fix it now before sheetrock goes up and everything is finished, then make him put it all back together (for free)
The Following User Says Thank You to the_man For This Useful Post:
LateralConcepts (03-03-2011)
Old 03-03-2011, 09:19 AM   #7
"good enough"
I'd hate to see what other things this asshat thinks are "good enough". Sounds like prize to work with.
VIPlumber is offline   Reply With Quote
Old 03-03-2011, 03:05 PM   #8
how about cast iron or galvanized steel DWV pipes? What are the proper ways of capping those?
Old 03-03-2011, 05:31 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 674
Not always legal, but these are often used-
Old 03-03-2011, 07:11 PM   #10
HVAC / Plumbing
I use these plugs alot
kenmac is offline   Reply With Quote
Old 03-03-2011, 07:24 PM   #11
MikeKy55's Avatar
Rewards Points: 254
This is exactly what I did when I relocated a vent line in my basement. But I ground the concrete down about a 1/2 inch along with the PVC and glued in one of these plugs and then filled over it with some quick setting sand cement mix.
MikeKy55 is offline   Reply With Quote
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
getting rid of unused pipe altadata Plumbing 5 02-05-2009 06:05 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
