Plugged Master Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2006, 10:57 PM   #1
Plugged master shower drain
I ran some brocolli through the kitchen garbage disposal (everything runs smoothly) and now the master shower drain has backed up with pieces of brocolli! I have never had this happen anywhere I have lived, nor have I ever heard of this happening. What should I do?
tam331 is offline   Reply With Quote
Old 12-07-2006, 12:33 AM   #2
747
registered
747's Avatar
Rewards Points: 534
Your going to have snake out the drain line. I also don't understand why it would have came up at the shower. Unless the drain line needed to be snaked after the shower because it had a little clog in it. You can go to any home improvement center and buy a hand held snake. I bought one for like 6 or 7 or 8 dollars i use it once every 3 months to snake the bathtub i take a shower in just because i like the water to go down immediately.
747 is offline   Reply With Quote
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 10:20 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Shower Drain Blaze25 Plumbing 1 01-19-2007 05:25 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
shower drain nomoney Plumbing 4 05-19-2006 10:27 AM
