Plug For Shower Pan Test - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2012, 04:14 PM   #1
Sheet metal mechanic
plug for shower pan test
Instead of forking up the money for a 2" pneumatic drain plug ($20 to $30) which I'll only use once, I heard that an inflated balloon will also do the trick. Any comments out there?
TMMiller is offline   Reply With Quote
Old 06-16-2012, 05:23 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Never tried it cuz I have a box full of test gear. Give it a whirl and report back
The Following User Says Thank You to TheEplumber For This Useful Post:
TMMiller (06-18-2012)
Old 06-17-2012, 02:19 AM   #3
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
how much head pressure are you looking at?
wctekkk is offline   Reply With Quote
Old 06-17-2012, 06:50 AM   #4
DIY staff
Rewards Points: 7,174
I believe he is doing a shower pan flood test---
Old 06-17-2012, 09:26 AM   #5
Rewards Points: 6,652
Look in your kitchen cabinet. There should be a lid large enough to place over it. You can seal with silicone caulk that you can remove with no problem.
Old 06-17-2012, 06:34 PM   #6
shower pan liner flood test
That's correct. I'm doing a flood test on my shower pan liner. I heard that a balloon (tied to a string) and shoved down into the drain will also work. I really don't want to spend $20 to $30 for a pneumatic test ball plug that I'm only going to use once. Any more thoughts out there?
Old 06-17-2012, 07:52 PM   #7
DIY staff
A balloon type of plug is needed --there is a lower drain/weep holes below the packed deck mud--
So the pipe needs plugging a few inches below the deck mud--
Old 06-18-2012, 10:12 PM   #8
Smile
shower pan liner test
Hey eplumber! I just tried a small balloon for my shower pan liner test. It seems to be holding back the water just fine. I happened to have some old small water balloons and blew one up to about 2.75 inches in diameter (my drain is 2") and worked it down into the drain past the weep holes. I added water tonight and will check it tomorrow after work. Just saved myself $20 to $30 dollars by not buying a test ball plug.
Old 06-19-2012, 01:56 AM   #9
Plumber
Rewards Points: 452
Let's hope it holds.
I had a good chuckle at your balloon idea. I pictured a DIY'er on his knees with his lips to the drain huffing on a balloon
But hey, for $20......
Old 06-19-2012, 10:24 AM   #10
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Lots of people will do way more ridiculous stuff for less than 20 bucks.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
TMMiller (06-19-2012)
Old 06-19-2012, 10:23 PM   #11
Balloon Plug
The balloon somewhat held the water back. Since an actual pneumatic test ball plug goes up to 13 psi - the balloon obviously not, there was a slight weepage down the drain which I could hear when all was quiet. I went to our garage (my shower is above) and looked for tell-tale signs of any leakage and found none. I had previously removed the sheetrock overhead to rework my drain and left the sheetrock down untill i'm done with the project. If the drain wasn't accessible, then I would recommend using a real test plug, but it held water long enough overnight so that I could check the entire underside of my shower the next day.
Old 01-07-2016, 08:18 PM   #12
Rewards Points: 12
Cool
Cheap plug solution that really worked!
I also didn't want to fork over the dough...and as I was walking through Wal-Mart I noticed how perfectly sized a raquetball was to stop up the 1.5" drain pipe below the weep holes.... I just needed to make sure I could get it out when finished. The solution was to cut a 1" hole on the top side of the ball with a utility knife (this also helped it not to float). I could then grab the side wall and pull it right out.
I tried it, and it worked perfectly...
before filling the pan, I stuffed the ball into the pipe so that it was Stuck when lightly pulling up
russkateer is offline   Reply With Quote
Old 01-07-2016, 09:08 PM   #13
Rewards Points: 1,770
Look for something like this
http://www.supply.com/shop?nid=47412...FQyFaQodzrANyg
Ghostmaker is online now   Reply With Quote
Old 01-08-2016, 12:56 PM   #14
Rewards Points: 289
I often wondered about those drain cleaning guys on the other site talking about strangest things they have remove from drains. I would ask how those things would even get in the drain in the first place. I am now starting to get the picture. I guess thats what they mean with homeowners keeping the pro's busy.
ct18 is offline   Reply With Quote
Tags
leak test , plug , shower pan
switched plug dm18 Electrical 1 10-31-2010 07:18 AM
Air compressor 230V plug? Jackslap Electrical 4 10-16-2010 10:04 PM
Wrong plug? alpercata Electrical 6 12-30-2008 11:40 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 08:44 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
