Old 06-28-2010, 01:36 PM   #1
plug drain
How to remove cement from a floor drain?
bobber99 is offline   Reply With Quote
Old 06-28-2010, 02:54 PM   #2
Handyman
plug drain
If you mean some has fallen into the drain, shove a shopvac hose down
canadaclub is offline   Reply With Quote
Old 06-28-2010, 03:15 PM   #3
plug drain
How much cement? What is the pipe material? Has it dried yet? If the cement is still wet, you should be able to get most of it with a shop vac. If its dried, you can try breaking it up with a screwdriver and hammer and vacuuming up the pieces, but be careful with PVC pipe. If the pipe is entirely full, you'll have to replace the pipe from the trap to the drain.
The Engineer is offline   Reply With Quote
Garage floor drain plug oxicottin General Discussion 2 07-26-2009 09:21 PM
foot lock drain plug..how to re-assemble? firsthomenewb Plumbing 1 03-01-2009 01:53 PM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 08:42 AM
Washer tray drain plug proofer Appliances 5 08-24-2008 09:53 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
