-   -   plug drain (http://www.diychatroom.com/f7/plug-drain-74870/)
bobber99 06-28-2010 12:36 PM
plug drain
How to remove cement from a floor drain?
canadaclub 06-28-2010 01:54 PM
If you mean some has fallen into the drain, shove a shopvac hose down
The Engineer 06-28-2010 02:15 PM
How much cement? What is the pipe material? Has it dried yet? If the cement is still wet, you should be able to get most of it with a shop vac. If its dried, you can try breaking it up with a screwdriver and hammer and vacuuming up the pieces, but be careful with PVC pipe. If the pipe is entirely full, you'll have to replace the pipe from the trap to the drain.
