Plug A 2" Drain In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2013, 10:23 AM   #1
Plug a 2" drain in basement
What's the best way to plug a 2" pvc drain line so it will be flush with the basement concrete floor.
I rerouted a 2" drain over a few feet along the main steel I-beam in my basement and tied into the main waste line.
I'm finishing the basement and don't need this drain any longer. I want to seal it up properly and eventually will have tile floor over it.
My thought was to cut if off flush with the floor and then insert a pipe plug (compression type with the wing nut) below grade so that the remaining cavity could be filled with cement or mortar. Thinking this would be about 2 cups full of mortar on top of the plug.
Or should I tile around this, cap it with a decorative cap and have access to it in the future if plans change or as a cleanout?
poorboy01 is offline   Reply With Quote
connecting clawfoot tub to existing drain line in concrete basement michaelflinn Plumbing 0 07-02-2012 05:48 PM
Plumbing DIY basement drain oops ddguy Plumbing 14 05-20-2012 07:11 PM
Lowering basement slab and installing drain tile diybrad Concrete, Stone & Masonry 0 04-26-2012 10:36 AM
Basement Shower Drain bigbran Plumbing 3 02-22-2011 10:21 AM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
