Pls Help! Toilet Emergency! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2007, 09:14 AM   #1
Question
pls help! toilet emergency!
hi!
my toilets blocked, and my mum is trying everything in her might to unblock it. shes used plungers, coathangers, everything! but it isnt working?
i think it's got something to do with me maybee puttin too much tissue in there, even a possible baby wipe?
please help, she's going mad
xx
help_me:) is offline   Reply With Quote
Old 02-05-2007, 09:24 AM   #2
One common mistake with plungers is trying to "push" the clog out. The plunger should be placed in the bowl and slowly pushed down and then pulled quickly back (creating suction). This pulls the clog back into the bowl. You may need to buy/rent a closet auger. This tool will go approximately 3' through the toilet trap and pipe. Good luck and let us know how it went.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-05-2007, 09:29 AM   #3
Post
update!! :P
my mum just said shes brought the wrong plunger, that its for a sink not a toilet. is there really a difference?
now shes putting hotwater down the drain; does this help?
xx
Old 02-05-2007, 09:47 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Do NOT put hot water down a toilet. It may melt the wax ring seal between the toilet base and the flange, causing it to leak...a bigger problem than a clog.
As previously advised, borrow, rent or buy a crank-handle toilet auger, feed the auger into the built-in trap of the toilet and crank away. That will usually break up a paper clog.
A toilet plunger has a rubber "bell" on it for reaching the bottom of the bowl, and it is best if you can pull the clog back out with it, as described, rather than trying to force the clog down (it may just compact it).
NEVER put anything down a toilet except toilet paper. It will most likely clog the trap, and even too much toilet paper can clog it.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-05-2007, 11:31 AM   #5
I hope you didn't have the problem I just had which is solely clog by human waste.... sounds impossible... but it is in my case...
I end up remove the toilet physically and replace one which is much better in terms of everything got out smoothly...
the quality of the toilet, in my case, make the difference here...
if this is the same in your case, you may want a permanent solution for replacing a better quality toilet....
KUIPORNG is offline   Reply With Quote
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 02:22 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 11:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
