Pliers For Garden Hose Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2011, 04:56 PM   #1
Chicago, IL
Michael Thomas's Avatar
Pliers for garden hose fittings
Saw this used the other day, want to buy them, but can't seem to GOOGLE them up:
A pair of pliers with offset jaws shaped to fit a female garden hose fitting.
Anyone know what these are called, or have a link?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 01-11-2011, 05:16 PM   #2
The ones that I use are called slip joint water pump pliers, brand name Channellock.
VIPlumber is offline   Reply With Quote
Old 01-11-2011, 06:36 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,.. I use off-set channel-lock pliers...
Old 01-11-2011, 07:08 PM   #4
Chicago, IL
Thanks, but it was not a conventional slip-joint, the jaws were at right angles to the handles, so that you could turn the fitting when you did not have access from the side.
Old 01-11-2011, 08:15 PM   #5
Remodeler
adpanko's Avatar
Rewards Points: 150
V Jaw Channellocks
Normal Channellock pliers work fine for hose fittings, as the previous poster said. But Channellock also makes a V-Jaw plier that would work a little better:
http://www.channellock.com/Category.aspx?zcid=104
adpanko is offline   Reply With Quote
Old 01-12-2011, 06:43 AM   #6
Chicago, IL
I'll call the service company today, and see if they can identify the manufacturer.
Old 01-12-2011, 11:17 AM   #7
Chicago, IL
Pliers for garden hose (clothes washer hose) fittings
Found them!
- Washer Fill Hose Pliers
Last edited by Michael Thomas; 01-12-2011 at 11:26 AM. Reason: Added title for future search
Old 01-12-2011, 02:08 PM   #8
Alright! Another tool to add to my bags.
Old 01-20-2011, 06:49 AM   #9
Chicago, IL
Got them, for future reference:
QB Products "Sure Grip Inlet Hosepiler", Part # THP-1, QB Products 1260 Karl Court, Wauconda, IL 60084.
New House + PEX + Plastic Fittings = ? GaryZ Plumbing 22 01-06-2011 08:47 AM
Hose fittings cellophane Landscaping & Lawn Care 2 06-01-2010 09:50 AM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
Drain hose stuck on washing machine savingedmund Plumbing 3 05-10-2009 10:19 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
