Please Take A Look At This Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2007, 12:05 PM   #16
Custom Cabinet Maker
Pesphoto; A serious suggestion; When the plumber takes that wye out have a company there to run a camera down that pipe! Find out NOW what other conditions you are dealing with. For all you know everything could be fine underground but to me it sure as Heck would be worth it to know for sure.
If they find real problems like it or not Deal with it NOW, no matter the cost at this point cause if you wait for total failure the cost will skyrocket.
Just my humble opinion.
skymaster is offline   Reply With Quote
Old 11-26-2007, 12:11 PM   #17
How would i find such a company? Also, Im not sure exactly what day he is coming to fix this. He is calling day of this week since he is so busy and is sqeezing me in the schedule. Do plumbers ever do this to check out the pipe?
pesphoto is offline   Reply With Quote
Old 11-26-2007, 01:42 PM   #18
Some plumbers do tho equipment is quite expensive. I would think a trip to the Yellow Pages would be ez and quik. This can be done independant of the plumber. I was only thinkin since plumber is "there" now is time to find out if it will be easier in long run to fix present problem or just put that money into replacement instead if the situation looks really bleak. NOT being a downer here just practical. If the entire system is compromised then whatever you do to fix this problem will only have to be ripped out to do the rest.
Other thought is to call building dept in your town and ask them for a person who can snake a camera into the drain, and you can explain why since this will require a permit to replace the line if needed. They normally know who those folks are, plus if they give ya a person you know you can trust them cause if they screwup you did get them thru the town and the town dont play well with folks that screwup :}:}:}
Jack
Old 11-26-2007, 01:47 PM   #19
Thank you Skymaster. That is great info, I really appreciate it. I will look into that.
Old 11-26-2007, 03:02 PM   #20
pesphoto---
if you live in Canada you could always call Mike Holmes!! I love that guy. I once saw them pull a new sewer main through the old existing sewer main pipe so no diggin was required. They took a bullet shaped metal cap and fixed it to the end of the new pipe, attached a hook and chain to the loop on the tip of the bullet shaped piece and cranked on the chain to pull the whole new pipe right through the old one and hooked it right up to the sewer connection under the street.....amazing!
DIY4EVER is offline   Reply With Quote
Old 11-26-2007, 03:19 PM   #21
Hi, Im in the US. But I read about someone doing just that in this area.
Something to look at for sure if I need to go that route.
What about something like this:
http://www.rotorooter.com/residentia...eplacement.php
Old 11-26-2007, 06:21 PM   #22
Pes; Now you got all the answers :}, call em, get the pics, you did see their link to the camers stuff? :}:}:} If it needs the liner they can get right to it and the problems are all gone.
Good Luck
Jack
Old 11-26-2007, 08:01 PM   #23
Yup, I saw the video stuff. Im going to call my plumber first thing Tues. am to discuss to see if he offers this type of service. If not, I am going to give Roto Rooter a call. Dont want to piss off my regular plumber, so I'll talk to him first, but I gotta do what I gotta do.
Old 11-27-2007, 07:47 PM   #24
That one Guy's Avatar
If they use video inspection equipment you should be able to get a copy of the tape. The sewer line should make a transition from cast Iron in the house to any of the following materials that hold up better than cast Iron in the ground, asbestos cement, clay, concrete pipe, orangeberg, 3034 pvc, or sch.40 abs.
Pipe relining will only do you justice if there are no bellys in the line or offsets in the joints. You will basicly have the same bellys or whatever in your new lining to. Sounds like you need a company who is full service.
That one Guy is offline   Reply With Quote
Old 12-18-2007, 09:13 AM   #25
Plumber is here and currently replacing the leaky part. So far so good. Pipe is cut off and he is melting the okum as I write. They are going to snake out the sewer line for me as well.
Old 12-18-2007, 12:12 PM   #26
woohoo..it's fixed..no unexpected problems!
Thanks everyone for your help and advice.
Old 12-18-2007, 06:23 PM   #27
redline is offline   Reply With Quote
diagnose house wiring problem brhodewalt Electrical 7 05-06-2009 10:03 PM
furnace problem captjack HVAC 8 11-23-2007 12:15 PM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 06:12 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
