Please Help!! Well- No Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2011, 11:03 PM   #1
Exclamation
Please help!! Well- no water
Hi,
I have searched the website as best as I could and found several similar situations that were helpful, but none that were having the same issue that we are.
I have a submersible well and we have no water at all.
I also checked the water tank (pressure tank ) and it has no water, and no air pressure (showing 0) but has power. Is this a simple, bad water tank issue? or could it be something else? We have never had any issue with our well, so I am very green on the subject but we are pretty handy.
Beforehand, I would like to say that any help is sincerely appreciated and I am trying to fix this ourselves, because of our financial situation.
Again,
Thank you,
Stephanie
sd2006 is offline   Reply With Quote
Old 07-09-2011, 11:14 PM   #2
Well Stephanie,
Could the well be Dry?
Bad pump
Bad Presure switch
no power
Good luck
Tnut
tnut is offline   Reply With Quote
Old 07-09-2011, 11:52 PM   #3
Originally Posted by sd2006 View Post
Hi,
Again,
Thank you,
Stephanie
I would check that the pressure switch is functional. You can do this by turning the supply switch/breaker off and on and listen for the pressure switch click.
If the pressure switch is operating, verify that power is being applied to the pump feed wiring.
If power is applied and the pump still doesn't work, disconnect the power and test the continuity to the pump with a Volt/Ohm meter.
If there is no continuity, its a possibility that the pump has failed.
Is the well a drilled one? or was it excavated? Do you have any idea how deep the well may be?
If its a deep well, it can be a very difficult job to lift the pump up. The water line is usually full of water and a column of water. of a hundred feet or more is very heavy.
You may not want to hire a professional well person, but its very likely that your problem is beyond the DIY level.
Tags
water tank , well level , well presure , well water , well water pressure pump
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
