Please Help, Stuck Cartridge,Moen Single Handle Tub Faucet, - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2007, 06:50 PM   #16
Journeyman Plumber
Ron The Plumber's Avatar
Order it on line here.
http://www.plumbingsupply.com/tools.html
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-29-2007, 10:38 PM   #17
Talking
You Guys are the Best, Thank You
I appreciate all your help guys,
Boy, you Guys sure work Fast, Its great to know you guys are here for us, your information and assistance is deeply appreciated , and I speak for all of us here, You make life a much better place, because of your unselfish dedication to this site and its members. Best Wishes to you Guys, Always! Thank You...... ......Woodpecker
Woodpecker is offline   Reply With Quote
Old 04-01-2007, 07:56 PM   #18
broke it
I used the cartridge puller and the outside of the old cartridge remained in the pipe.
I will call the real plumber. No end of grief from my wife.
wenceslaus is offline   Reply With Quote
Old 04-02-2007, 06:58 PM   #19
check out this web site
ther Pages of Rages Ľ Stuck Moen Dialcet shower faucet cartridge replacement
and read the right side of the diagram, of the post My Buddy Big Dave posted for me. it has instrucions for removing the shell... but don't forget to click on the link, it will be very helpful..Scroll up and down on the site and read all posts..Good luck
Ron the plumber and Dave are Awwesome.
Also thanks Kui****g for you input I appreciate it!!!
Thanks Guys, You rule!!!
Old 04-03-2007, 07:47 AM   #20
Exactly what I needed
I'm off to Ace, no plumber for me today. thanks for directing me to this Woodpecker!
Old 04-04-2007, 01:18 AM   #21
Talking
No Problem~o
Hope everything comes out ok,
tee hee let me know, ok.
Old 11-12-2007, 02:01 PM   #22
Post
All these posts have really helped me out a lot already, especially the posted pics!
It seems I'm having the same problem with getting out my old Moen cartridge. I pulled out the inner core (with a tool that should've taken the whole thing out) and now I'm trying to get the outer shell out. I bought another tool (with the spring-loaded notch at the end) and now they're both lodged in the pipe and I guess I'm not pulling hard enough. I'm going to try some more and if I'm not successful, I'm going to employ some bigger muscles.
philosovee is offline   Reply With Quote
Old 11-20-2007, 05:56 PM   #23
How do I get the cartridge out of a moen single handle bathtub faucet
Richard Gielski is offline   Reply With Quote
Old 08-24-2010, 02:42 PM   #24
moen faucet stuck
Mean faucets are infamous of sticking. Build up of particles in the water causes the faucet cartridge to get stuck. Try using CLR on the unit, soak, and spray or drench the faucet with CLR. I may take a while for it to work. The CLR attacks the build up and breaks it down. Itís like using penetrating Liquid to remove a rusty bolt/nut. Vinegar will work but not as effective as CLR.
Ol'blue is offline   Reply With Quote
Old 01-26-2014, 05:28 PM   #25
Single knob tub faucet cartridge part stuck
Alright, had a leak. Was pulling cartridge out and only the middle-center came out. The surrounding housing won't come out (the pin on it is out-and a small washer in there is as well). I stuck the center part back in there, "but" it is flowin water pretty bad. Water is shut down at moment. My retired plumber neighbor came and looked at it and said he'd never had that happen. Hence my nickname Never_easy. Thanks ahead of time
Never_easy is offline   Reply With Quote
Old 01-26-2014, 05:31 PM   #26
That's exactly what is happening to me right now!!! How did you get it fixed??? Did a plumber get to retire earlier thanks to you?
Thanks,
Never_easy
Stuck Cartridge Moen Single handle wenceslaus Plumbing 2 04-02-2007 06:47 PM
