Old 10-14-2007, 11:39 PM   #1
Angry
Please Help- No water in shower
Just replaced some pipes in the tub and now I have no water pressure. Please help us problem solve this- because we are completely lost as to what happened when it worked fine earlier this morning with the old pipes (which NEEDED replacing)
FrozenRain00 is offline   Reply With Quote
Old 10-15-2007, 01:10 PM   #2
I put the "why?!" in DIY
Were the old pipes by any chance severely corroded? If so it is possible that some of that corrosion broke off and plugged the mixing valve. Is there ANY water coming out?
jmancine is offline   Reply With Quote
Old 10-15-2007, 01:43 PM   #3
Exactly what pipes did you replace? And by "no pressure" do you mean a dribble of water comes out, or do you mean that the shower is bone-dry.
NateHanson is offline   Reply With Quote
Old 10-15-2007, 02:10 PM   #4
would it be just your facuet exhaust opening got corded... it happens to us once, when I try to change some pipes in the basement, I put some bread to absorb water before solidering... these breads end up cord up my facet upstair when I turn back on the switch... I end up change the facet, but I think I should have open it up and clear things out instead before going to that extreme....
KUIPORNG is offline   Reply With Quote
Shower Dripping Hot Water, Should I Shut Off Emergency Oil Burner Switch? bman46 HVAC 1 10-02-2007 03:04 PM
Water Pipe Size for Double Shower froddan Plumbing 12 08-03-2007 09:46 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
Shower Body, Toilet Water Supply Rough helpless handyman Plumbing 5 11-06-2006 09:51 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
