Old 02-12-2008, 02:14 PM   #1
Please Help No Heat In Upstairs Radiator Downstrairs Is Fine
My temporary fix has been to force water into the furnace and bring it to about 11psi. I then bleed the radiators until i get water. This works for a few weeks or so then I lose heat agian. It seems that i lose water and pressure. I have no leaks in the house. Its a small area 800 sqft to heat so its not a big system....any ideas or advice/help would be great!!!!
Thank You
CARL7480 is offline   Reply With Quote
Old 02-12-2008, 03:16 PM   #2
How old is the expasnion tank?
The furnace should "fill" on its own.
Do you bleed the system?
redline is offline   Reply With Quote
Old 02-12-2008, 03:39 PM   #3
the first time this happened i emptied the whole system (nasty black water) and refilled. the tank i dont see a date on there i have been here 4 years so its at least that old.
Old 02-12-2008, 03:41 PM   #4
What is the PSI reading on the gauge at the boiler?
Old 02-12-2008, 04:57 PM   #5
Right now the pressure is 4-5 psi
Old 02-12-2008, 05:05 PM   #6
Electrician
I would say you need at least 12-15psi to make it to the second floor, do you have an autofill installed into the system?
chris75 is offline   Reply With Quote
Old 02-12-2008, 05:38 PM   #7
Send a message via AIM to Marlin
The boiler should maintain 12-15psi as has already been stated. Your fill valve is probably broken. Manually raise it to 15psi and see if that helps.
Marlin is offline   Reply With Quote
Old 02-12-2008, 06:58 PM   #8
that does help for a few weeks then this happens again....i guess i can change the valve this weekend...how do i know if it is the circulator pump ? I cant tell if it is working or not...
Old 02-12-2008, 08:34 PM   #9
The circulator pump has nothing to do with the pressure which we have already established is your problem. Go to your local plumbing supply and get yourself a new fill valve. I recommend against Home Depot, Lowes, or any other big box stores. They tend to go for the cheapest stuff they can get there hands on.
Old 02-12-2008, 08:37 PM   #10
biggles's Avatar
if the circulator pump isn't running you won't have any heat and the boiler would be satisfying itself on the limit due to the water not being circ'd.the pump should run when the stat calls motor should be warm to hot(depends on location around boiler)i am thinking you have a steam boiler not a hot water boiler...with loosing water and pressure but no leak?
Old 02-12-2008, 08:39 PM   #11
Ok, hold everything for a minute.
I assumed this was hot water. If you have steam ignore the previous advice, you have a different problem.
Old 02-12-2008, 08:41 PM   #12
Hot water boilers do loose water and pressure over time. I'm not sure exactly where it goes but if you shut off the supply to any boiler usually in a few weeks the system is going to be low. A new system can probably go a couple months but it will eventually get low.
Old 02-12-2008, 09:22 PM   #13
yes it is a hot water heating system....should i still replace the fill valve...that was the same question i was asking myself where is the water and air going ?
Old 02-13-2008, 05:45 AM   #14
biggles's Avatar
are you setting one stat for the whole house?the relief on the side of the boiler is it wet on the inside of the copper pipe(blow off) or right inside the brass fitting
Old 02-13-2008, 08:46 AM   #15
Yes just one thermostat for the house ..im sorry im not that good at these types of things ..when you say relief.. is that the spicket on the side at the bottom that i use to fill the furnace with water ?
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Please Help No Heat Upstairs Radiator Downstairs Is Fine !!! CARL7480 HVAC 3 02-13-2008 03:46 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 06:47 PM
