Old 02-28-2011, 12:44 AM   #1
Please help me, slow draining sink
I have a problem with a clogged bathroom sink. It's not in the trap and the toilet and the shower work fine. I tried chemical cleaner but that doesn't seem to work. The water just drains very slowly but nothing is making it go faster. I tried using a snake but it won't go any farther in and still won't drain normally.
Captainrivera is offline   Reply With Quote
Old 02-28-2011, 12:52 AM   #2
Un hook the ptrap then put your snake in. If your using liquid plumber good luck try using Zonk.
Adam_M is offline   Reply With Quote
Old 02-28-2011, 12:58 AM   #3
I have already unhooked the ptrap and I used a chemical called zed I got from homedepot. The snake only goes about a foot into the wall but doesn't seem to go any further.
Old 02-28-2011, 01:05 AM   #4
I mean zep not zed. Zep crystal heat is what I used.
Old 02-28-2011, 08:49 PM   #5
It's the Internet so I can give out a stupid idea with little fear, but if it drains some maybe a low flow of hot water for a few hours every day for a week will loosen it up? I'm only giving the idea because you tried/have a snake it seems. If the snake can't get through I wouldn't think chemical dissolvers will. Sounds like you're dealing with something much worse than some hair clogs.
Mrdippy is offline   Reply With Quote
Old 02-28-2011, 09:27 PM   #6
I don't know what it could be. Does it help that the pipe is cast iron?
Old 02-28-2011, 10:45 PM   #7
I have seen mud like and gritty kludge that won't dissolve with chemicals and poking wouldn't work on. One was a washer drain with gritty dirt particles, and the other was grandma's 80yo cast iron drain pipe. If you poke a clogged pipe the kludge redirects the force sideways against the pipe sides, and doesn't push it through
Old 03-01-2011, 11:24 AM   #8
I recently had the same problem. The final solution included installing new pipe from the sink all the way to the main stack. I had to cut a hole in my drywall under my sink so that I could cut out the sanitary tee; went under my house and cut the sink drain line as close to the main stack as possible; then ran new pipe back up to the sink and vent using ABS and Fernco fittings. Final cost was about $50 and that included a new sink pop up assembly.
The cause of my slow/non-draining sink? My two-inch cast iron drain pipe had so much gunk in it that there was less than a 1/4" of effective cross section left that wasn't blocked. Yuck...I kind of wish I had taken pictures.
loftezy is offline   Reply With Quote
Old 03-01-2011, 12:29 PM   #9
you need a larger more powerful snake, and the experience to make it turn 90 degrees. frequently the pipes are galv. and the fittings are cast. that is where rust forms to start the obstruction
plumberinlaw is offline   Reply With Quote
Condensate draining into sink drain fritzycat1 HVAC 0 01-23-2011 02:39 AM
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 6 09-22-2010 06:43 PM
slow draining bathroom sink brandonriffel Plumbing 6 06-17-2010 02:20 PM
slow draining kitchen sink Slowdrainer Plumbing 2 02-02-2010 01:56 PM
REALLY slow draining kitchen sink! stenton Plumbing 2 12-04-2006 06:45 PM
