Please...Help! Connecting Rough Pluming - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2008, 12:28 PM   #1
She'sapainter
Unhappy
Please...Help! connecting rough pluming
Hello I am hoping that someone can help me..We have just added a second addition upstairs I am now trying to connect my bathroom drain assembly to the wall pipe however its a rough finish i'm stuck? I was told to get a slip joint connector but I have nothing to screw it to frustrated and lost.
tverhoef is offline   Reply With Quote
Old 02-24-2008, 12:35 PM   #2
You should have an "arm" (piece of pipe) coming out of a tee that is in the wall. This is where the slip-joint is connected. Without being to see the set-up you have, a picture would really help. Maybe you can take one or two and go to Photobucket to be able to put them in this site.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-24-2008, 01:12 PM   #3
She'sapainter
The tee pipe is already connected and the 1 1/2 in pipe is coming out of the wall, howeverthere is no threads on this copper waste pipe to connect the nickle drain pipe to, to keep it tightly fit together.
Old 02-24-2008, 01:51 PM   #4
Custom Cabinet Maker
they make a dwv fitting that is compression to compression just for that. Or you can get a sweat fitting that solders to copper and compression for the dwv
skymaster is offline   Reply With Quote
Old 02-24-2008, 02:05 PM   #5
biggles's Avatar
check out his diagram on the final connections
Old 02-24-2008, 02:19 PM   #6
If you do not want a compression fitting, use a Desanco fitting sweat onto the copper pipe (best in my thinking). I have included a link to show you these fittings. Sidenote: In Florida, while working at Disney World, we used a sweatable brass set of threads on the end of the pipe. All it was is 4 threads that slid onto the pipe and was sweat in place.
http://www.watts.com/pro/_products_s...=68&parCat=643
Old 02-24-2008, 04:26 PM   #7
Majak: :}:}:}:} Yep thats the sweat fitting We dont have that Danesco name up here in Yankee land LOL LOL It is too sophistacated fer us
Old 02-25-2008, 12:17 AM   #8
Skymaster,
I am originally from Ohio, where i served my apprenticeship. Florida wouldn't recognise that word. Now in Arkansas, you may just find a piece of kinked hose with a radiator clamp on it. LOL.
Old 02-25-2008, 11:16 AM   #9
Majak: I hope that clamp is Stainless LOL LOL. Where bouts in Clinton land? I have a friend who moved to Mt Home, He tried to get me to move out there but when I went out, at least 10 years ago It was too damn hot and just didn't do it for me. I flew into Baxter Airport. Now I no longer fly :{:{:{:{
way way too expensive now.
Jack
Old 02-25-2008, 12:42 PM   #10
She'sapainter
I thank you all for your input I am a painter and I still live where I served my apprenticeship. But I don't have a clue about plumming.
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
Old 02-25-2008, 01:26 PM   #11
Tv; First rule of plumbing: *hit rolls downhill LOL all other rules are based on rule #1
Old 02-25-2008, 05:44 PM   #12
Skymaster, I live in Lafe AR. A berg of about 500 people. Nearest big city is Jonesboro, where Arkansas State U is located, and it's 30 miles away. There are no code inspectors here. You build a house and hope everything works. Darndest thing I have ever seen. I live out in the County and it's mostly farms. Living in Florida was bad enough. Never saw galvanized allowed on gas lines, let alone being required. This is something people need to realize when answering questions in DIY Forums. The rules are different in different places.
Old 02-25-2008, 06:01 PM   #13
Amen Majak, I always keep that in my mind. Now tell me what is wrong with a 3/4 rubber hose made by Goodyear for a water main? LOL LOL
Cellar to rough basement? javamom Remodeling 1 06-27-2006 05:23 PM
Are fascia boards rough carpentry? Paul58 Building & Construction 10 04-19-2006 11:18 PM
How to get a rough quote on a basement?? cloudkicker101 Building & Construction 4 04-18-2006 12:48 PM
