Old 02-13-2007, 09:50 PM   #1
Please describe exactly side sewer TEST
Hi - I paid for a permit to do side sewer and I think I know how to do it except I'm not familiar with how the inspector will typically want to do a test. I believe I must install a "test Tee" as close as possible to the city
6" stub at prop. line. Then my neighbor said you put a balloon type thing in there to plug it and using a section of pipe of (____number of feet?)vertical into the cleanout closest to house foundation.
Then fill with water and see if it holds for (______amount of time?)
I plan to use 4" SDR35 gasket pipe until about 3' from the foundation and then join to 4" ABS that comes out of crawl space. Do I join those two different type of pipe with a "fernco" rubber fitting and stainless straps? Or is there another way thats better?
Thanks anyone.
wannabuild is offline   Reply With Quote
Old 02-14-2007, 08:34 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Ten feet of pipe, no time limit, leave it till inspection is done, fernco will be fine for the connection.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-14-2007, 08:44 AM   #3
Thanks for Help.
Whirlpool Side By Side Not Making Ice Anymore!! handy man88 Appliances 57 07-14-2011 07:33 AM
Sewer Pump: How to make do? austinbirdman Plumbing 2 05-04-2011 10:35 PM
Noisy Frigidaire side by side EZ Rider Appliances 7 03-12-2008 01:51 PM
Cathedral ceiling without sofit vent on one side ChrisO Roofing 3 01-31-2007 11:51 AM
Sewer leak below slab. Debris in sand. martin52 Plumbing 2 10-20-2006 09:43 AM
