Plastic/Shark Bite Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2009, 05:53 PM   #1
These are the fittings that are push on not crimped, and are not cheap. Plastic inserts in these fittings break and I cant find a source. Anyone know where I can locate these
AJ&J is offline   Reply With Quote
Old 03-23-2009, 09:06 PM   #2
you could call the company and they might send you some, most sharkbite fittings are guaranteed for 25 years... i imagine those plastic inserts would be part of the warranty.
scotty123 is offline   Reply With Quote
Old 03-23-2009, 09:11 PM   #3
Remodeling Contractor
If you are referring to the white plastic inserts that are only needed if you are connecting CVPC pipe and such, get them at any plumbing supply. They are sold separately but distributed with the fitting in case you need them. Not used for copper or Pex.
Old 03-24-2009, 12:21 AM   #4
Rewards Points: 168
I kept my plastic insert in my shark bite going into copper.Will i have any problems?
hidden 1 is offline   Reply With Quote
Old 03-24-2009, 04:49 AM   #5
http://www.sharkbiteplumbing.com/How-To-Install-W6.aspx
mark942 is offline   Reply With Quote
Old 03-24-2009, 11:21 AM   #6
Rewards Points: 168
thanks for the link..i guess since mine is already in with tubing insert and working fine then it is ok to leave in.(copper)..but next time remove it!?
Old 03-24-2009, 05:30 PM   #7
"The SharkBite® fittings have an integral Tube Support Liner that supports PEX tubing to the o-ring inside the fitting. The Tube Support Liner is not required for use with CPVC and copper tubing; however these two types of tubing fit over the Tube Support Liner easily and hold it against the tube stop. Follow the steps below to remove the Tube Support Liner from the SharkBite fitting."
Old 03-25-2009, 06:55 PM   #8
Rewards Points: 168
again i ask..will it hurt anything to leave it in since its already working fine ?
Old 03-25-2009, 08:09 PM   #9
GC/Master Plumber/Mech
Rewards Points: 560
No it will not
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 02:01 PM
plumbers shark bite fittings jburkeg Plumbing 9 11-12-2007 10:29 AM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 08:16 PM
