Old 07-03-2006, 11:50 AM   #1
Plastic Bushings???
I am installing new 1/2" and 3/4" copper pipe in an addition.
I keep hearing about and even saw a picture (in B&D Home Plumbing) of plastic bushings that get inserted in through holes in studs and floor plates.
These bushings are supposed to help keep the pipes from rattling and binding.
Anyone know where I can find them? I called all the bigger plumbing supply places in my area and no dice. I tried to do searches on the net and no dice.
A website URL, phone number, etc would be very helpful. Are they called bushings? I saw something called pipe insulators. Are those the same / right thing?
dcgray2 is offline   Reply With Quote
Old 07-03-2006, 06:48 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Plastic Bushings???
There called pipe insulators, there for 1-3/8 holes, they make them for 1" 3/4" 1/2" pipe sizes.
You may have to get them and a plumbing supply house.
Big Box stores may not sell these.
Ron The Plumber is offline   Reply With Quote
Old 07-03-2006, 09:29 PM   #3
Journeyman Plumber
Plastic Bushings???
Here is a link to them.
http://www.lspproducts.com
Old 07-04-2006, 08:12 PM   #4
joed's Avatar
Plastic Bushings???
Link is not working for me.
Old 07-04-2006, 08:20 PM   #5
Journeyman Plumber
Plastic Bushings???
I changed the link, click your way to it.
Products > Speciality Products > Clamps
Top picture is what it looks like.
Old 07-05-2006, 06:09 PM   #6
joed's Avatar
Plastic Bushings???
Tha link stil not working. Try this one.
Old 07-05-2006, 06:27 PM   #7
Plastic Bushings???
Thanks for the replies. I am assuming that "you" (you know who you are) would reccomend these? Or is there a "better" way? Thanks again!
Old 07-05-2006, 06:42 PM   #8
Journeyman Plumber
Plastic Bushings???
Recommened and used all the time by plumbers.
Old 07-06-2006, 01:20 PM   #9
Plastic Bushings???
I called the local places and asked for the correct thing. No one has them in stock. I finally called LSP directly to ask about distributors in my area. Turns out one of the places I called that said they didn't have them and couldn't get them IS an LSP distributor! I called them back and they won't order them without me buying a qty 100 of both 1/2" and 3/4" and pay for shipping... So unless I'm willing to spend $85.00, no pipe insulators for me... Any other suggestions? What about "stuffing" pipe insulation (rubber not the foam stuff) around the pipe in an opening?
Old 07-06-2006, 08:24 PM   #10
Journeyman Plumber
Plastic Bushings???
Code does not require insulators, code only states support is required, you could just use plastic strapping, to secure the pipe, or even plastic coated wire hangers where the pipe passes through the holes.
Old 07-10-2006, 05:03 PM   #11
Plastic Bushings???
Consider Oatey 33950 Insulating Pipe Clamp 1/2"….
http://www.plumbersurplus.com/Produc...t=1074&Mfr=142
Oatey 33951 Insulating Pipe Clamp 3/4"…
Know that for drilling, the actual hole size is much larger to accommodate the insulating features.
PSZach is offline   Reply With Quote
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Corrugated plastic fixtures tonydee Roofing 4 07-16-2008 11:36 PM
Styrofoam vs. Plastic vent channels dpreznik Roofing 14 05-10-2007 03:58 PM
Where to find 2½" square plastic drain pipes The_Flash Roofing 4 07-25-2005 08:35 AM
